Letter 35060
Glossy black finish on carbon steel
Hello,
I currently have some carbon steel tubes that have been heat-treated
and welded.
Traditional coating for them has been black-oxide, however some
customers would like to see a glossy black finish on them. I have
tried polishing the surface before plating(black-oxide), the results
weren't glossy enough. Of course I'm looking for something cost
competitive with the black-oxide. Any help would be greatly
appreciated.
Gene Degre
Metal Stamper - Worcester, Massachusetts
You may have tried polishing, Gene, but you didn't try hard enough
Don't give up. A high quality black oxide on a highly polished
surface can give you a finish that looks like a jewel.
finishing.com
Brick, New Jersey
Black oxide is traditionally oiled or waxed for better corrosion
resistance. Look at a black wax.
Oil it sparingly with any eddible oil (
Linseed Oil [link is to product info at Rockler] is best)or 20%
shellac solution,then heat it slowly to 4oo C.Repeat if need,and then
lacquer it.
- Zagreb, Croatia
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
