finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 34090
Galvanic corrosion of chem-filmed aluminum
I have a unit that is made of aluminum (6061)that has been chem filmed to Mil-C-5541 [link is to spec at TechStreet] -3. In installation, it interfaces with two 300 series stainless steel pins. In humid environments, will the chromate conversion coating, although conductive, serve as a barrier between the aluminum and stainless or do I still risk galvanic corrosion where they contact?
Lou Volka
Aerospace manufacturer - Farmingdale, New York
I would suspect that the pins will scratch through the film to create direct contact with the aluminum, which creates a potential for galvanic corrosion. SS is not as active in causing galvanic corrosion of aluminum as is plain steel, but there is certainly a possibility, especially in the crevice of the pin bore where the SS will tend to lose passivity.
You could check test assemblies with a voltmeter to see if you have electric conductivity between the pin and aluminum. If you have a low resistance, there is electical continuity and a potential for galvanized corrosion.
Larry Hanke
materials testing laboratory
Minneapolis, Minnesota
