finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 34079
Galvanized vs. electroplated bolts, nuts and washers
Dear sir,
We have to supply some fabricated structural members along with fasteners.The client's specification for the fasteners says that HM 8.8 BOLTS, NUTS AND WASHER-Galvanized.
This instance could I supply these fasteners which has been galvanised by electroplating method? And please advice what is the difference between the hot dip and electroplated.
Thanking you
Velayudham Ravishankar
structural fabricator - Manama, Bahrain, Kingdom of Bahrain
Hi, Velayudham.
Hot-dip galvanized coatings are far heavier than electroplated zinc and will exhibit greater corrosion resistance. It is never permissible to make a substitution without approval because one never knows the intent of the designer. For example, zinc electroplating is also susceptible to zinc whiskers whereas galvanized coatings are not believed to be. If these items are intended for a computer room or hospital life-support equipment, for example, you could have great liability if you substitute. Good luck.
finishing.com
Brick, New Jersey
I agree with Ted.
Hot Dip coatings are usually thicker, better bonded and will probably perform better than electroplated zinc, which are commonly more used for cosmetic purposes only. We find these fasteners are only well protected in stored conditions. For structural fabrications, if atmospheric corrosion is your concern, I would get the client to agree on a design change.
But does it ever actually rain in Bahrain?
Martin Rich
- Plymouth, Devon, UK
Mr Ravishanker
Hot dip galvanising puts a thick zinc layer all over the part and does protect well. There are Electro Galvanising (electroplated) Zinc iron alloys that perform very well and compete with Hot dip galvanised coatings for Corrosion resistance. These bear a look .
Asif Nurie
Atlanta Global
New Delhi, India
Is it really the case that electroplated zinc coating is mostly cosmetic?
Would you also offer your opinions on fasteners in ACQ-treated wood in outdoor structures? Does the particular copper-rich formula of ACQ accelerate corrosion of galvanized nails, screws, and bolts?
I use 1/4" to 3/4" diameter bolts, mostly 3/8". I use either hot-dipped or electroplated zinc bolts. Should I not use electroplated any more?
Michael Cohen
playground design - Ithaca, New York USA
Zinc plating is fine for some applications, Michael, mostly indoors -- but it's corrosion resistance isn't enough for rough outdoor service. The ACQ manufacturers have highly specific recommendations about fasteners (most likely saying that electroplated fasteners are not acceptable but hot-dip galvanized fasteners may be); yes, copper in the wood will greatly accelerate corrosion due to the galvanic couple.
finishing.com
Brick, New Jersey
I HAVE RECEIVED SOME 3 METER CHANNEL CROSS ARM WHICH IS ELECTRO GALVANISED. DUE TO HEAVY RAIN IT IS GETTING CORRODED. WHAT MEASURE I HAVE TO TAKE FOR STOPPING CORROSION AND ANY ZINC SPRAY WILL HELP TO STOP THE CORROSION. IS ELECTRO GALVANISED OR HOT DIP GALVANISED GETS CORRODED FASTER. AWAITING YOUR EARLY REPLY WITH SOLUTION TO RECTIFY THE DEFECT.
N.JAYAKUMAR
- TRIVANDRUM, KERALA, INDIA
Investigate replacing it, N. "Electro galvanized" is a euphemism for zinc electroplated. This is usually inadequate for outdoor service. But the "cold galvanizing spray [linked by editor to product info]" that you mention (which is actually zinc-rich paint) is pretty good at deterring corrosion. It is not nearly as attractive as electroplating though.
finishing.com
Brick, New Jersey
I'm under the impression that the thickness of the zinc coating is based on the standard or procedures for the specific galvanizing process. For example, a hot dipped galvanized piece could be galvanized to a lesser zinc coating thickness than an electrogalvanized piece. (Typically not the case, but as an example.) Are my assumptions correct? I've spent a little time researching this...Also, the thickness of the steel must have an effect on the thickness of the zinc coating, right? Is or are there any studies or information documenting this?
David Riley
contracting - Piscataway, New Jersey
Hi, David. The thickness of electroplated zinc on hardware is typically controlled at anywhere from from .00015" on up to a practical limit of about .0006" according to specific needs. The upper limit is essentially based on practicality in that it takes over an hour of zinc plating time to reach .0006" in barrel plating and it becomes uneconomic, and you're approaching beating the fastener to death in the plating tank :-)  The thickness of the steel has no effect on the thickness of electroplated coatings; it's a function of the electroplating current and time.
Hot dip galvanizing is never that thin. Typical thicknesses for fasteners are .0015" to almost .004". In general you can't readily control the thickness; rather it depends on the surface condition of the steel. Thicker steel takes longer to heat up and usually takes a heavier coating.
In all, it might be theoretically possible for a very thick electrodeposited zinc coating to approach the thickness of a very thin hot dipped coating, but it is rarely heard of. Rather, a "rule of thumb" might be that galvanizing is about 5x as thick.
finishing.com
Brick, New Jersey
May 25, 2008
What is the difference between Galvanised Iron and hot dip galvanised iron. Are both the same or electroplated iron is called as GI ?
Syed Mohamed Gani Gani
coating inspector - India
May 27, 2008
Hi, Syed.
The phrase "electrogalvanized", which means zinc electroplated, has become pretty common usage. But to my mind GI means "galvanized iron" and "galvanized" means hot dipped. Unfortunately, it's hard to put a fine point on words like this. Because although I can say "electroplated" is not "galvanized", a supplier of the electroplated finish can always say "I've always called it galvanized; try to stop me!"
finishing.com
Brick, New Jersey
June 25, 2008
Hello Ted,
it looks like you are very knowledgeable in this field.
I heard of the stop of production in China during the Olympic games, due to heavy pollution. There they say that electroplated zinc method is of far higher pollution than the galvanised method. Can you tell me why there is so big difference in pollution?
Thanks for your help and best regards from Hamburg.
Reinhold
Reinhold Becker
- Hamburg, Germany
June 25, 2008
Hi, Reinhold. Sorry but I have no idea what production China will halt during the Olympics. But here in the USA, and probably in Germany as well, it has been many years since an electroplating plant has been permitted to pollute.
It is difficult or impossible to calculate the environmental impact of one process against any other. So I would turn the question around and ask the person who claims that electroplating is more polluting than galvanizing to present any calculation whatsoever to promote his case and give me a shot at tearing it apart.
In the best light most such claims are based on highly subjective and transient interpretations of environmental impact.
finishing.com
Brick, New Jersey
July 1, 2008
Hi Ted, thanks for your reply. Surely there are, as you mentioned, many points of view "what is pollution" (in general speaking) and what kind, style of pollution we talk about. I was just hoping it was easy to get get a reply like " method A is clearly considered to be more harmful because of ..... Therefore method B came into the picture". Best regards from Hamburg.
Reinhold
Reinhold Becker
- Hamburg, Germany
July 2, 2008
Can you give me a URL for a news report about this? I haven't heard about a shutdown, let alone one targeted against electroplaters. And I don't know who "they" are who claim that electroplating pollutes more than galvanizing, or what parameters they use in making such a claim.
I don't think method G came into existence as a result of pollution or perceived pollution by method E (they've both been around for over a hundred years) so I can't enunciate the relevant list of alleged pollution grievances :-)
But rather than belabor the point, I will say that E is a "wet process". Ions of the metal to be electroplated are dissolved into aqueous solution, and those ions are washed off with water. That introduces the potential of discharging water that may contain an excessive amount of the metal in question.
>Regards,
finishing.com
Brick, New Jersey
July 16, 2008
Hello Ted,
sorry for late reply. Here the URL you asked for
http://www.nytimes.com/2008/07/07/sports/olympics/07china.html
It looks like the main point they focus on is the air pollution. Is 1 of the 2 ways more harmful there. As it appears other pollution forms are not so much under focus.
Have a great day
Reinhold
Reinhold Becker
- Hamburg, Germany
July 2008
Hi, Reinhold. I saw mention of "coal mines, coal-fired power plants, steel mills, cement factories and other clusters of heavy industry" and "coking operations, cement factories and small power generators", but not electroplating or galvanizing.
No metal is released into the atmosphere by zinc electroplating or galvanizing, and it is relatively easy and inexpensive to scrub the acid and alkali fumes, so I doubt that either contributes substantially to air pollution.
finishing.com
Brick, New Jersey
July 1, 2010
Dear Sir
what is difference between galvanizing and electroplated washer? I will use washers for U BOLT together. Which can I prefer?
Serkan CAMAL
machinery - Turkey
July 6, 2010
Hi, Serkan. I'm sorry but I can't figure out what parts of this thread need clarification. We've said several times that galvanized coatings are applied by hot dipping and are much thicker and more corrosion resistant than electroplated zinc. We've said that they are less susceptible to metal whisker growth. Is that important for your application? They are not as attractive and they are significantly more expensive that electroplating. Is that important to you? Thanks.
finishing.com
Brick, New Jersey
October 12, 2010
Dear Sir,
Is there a general understanding in using different types of coating on bolts and nuts ? i.e. an electroplated bolt (zinc coated) with a galv. or black nut.
Obviously this is not the common practice but I came across a case that may be required since the material is already purchased.
Further, what would the affects be if an electroplated bolt is used with a galv. or black nyloc nut ?
Savas
Savas Onal
Construction - Melbourne/Australia
October 12, 2010
Hi, Savas.
Mixing hardware like that is difficult and may not be useful. It's difficult because the dimensions on galvanized fasteners are different and they tend to not join up well with black or electroplated fasteners.
The reason that it may not be useful has to do with the protection mechanism. Zinc plating or galvanizing does two things symbiotically. First, it protects the steel cathodically, with the zinc corroding/dissolving to keep the steel from corroding/dissolving. Secondly it protects the steel by coating it: while the corrosion products of steel are a fluffy non-adherent rust that does not deter continued rusting, the corrosion products of zinc can be highly adherent and build a good impervious skin against continuing corrosion. But if you have black hardware in contact with the zinc plated hardware, the zinc cannot protect the black steel by coating it, only by quickly dissolving away. Regards,
finishing.com
Brick, New Jersey
April 1, 2011
please, I need advise on process for cermet base coating and fluoropolymer topcoating of thread, how different is it from hot dip galvanizing.
Adeniyi Egbemode
- Osogbo, Osun and Nigeria
April 2, 2011
Hi, Adeniyi.
Cermet means ceramic-metal, like titanium nitride, but not necessarily titanium nitride. Most cermets are probably applied in PVD (physical vapor deposition) vacuum chambers. Fluoropolymer means an organic coating similar to Teflon. If only the threads are topcoated, I'd have to guess that the topcoating is a Teflon-like lubricant rather than a corrosion protection barrier.
It is difficult to answer your question properly in the abstract, though. What is your situation?
finishing.com
Brick, New Jersey
April 5, 2011
Thank you for your assistance
My situation is that I want to supply fasteners to an oil company in Nigeria; part of their requirement is have the fastener to be cermet base coat and fluoropolymer top-coating; at the same time some requirements is to have other sets of fasteners with bichromate treatment.
Adeniyi Egbemode
April 5, 2011
Hi, again. Steel does not accept bichromate treatment, so the fasteners you are speaking of must be zinc plated or cadmium plated, or something similar. It seems to me that you are trying to quote or supply fasteners when you have only vague instructions as to what is needed. There should be tight and definite specifications for what they want. Good luck.
finishing.com
Brick, New Jersey
May 24, 2011
Hello;
Does hot-dip galvanized nuts, washers, and bolts change color over time when exposed to the elements? If so what might the color and timeframe be?
Thanks;
Chris
Chris Au
- Vancouver, BC, Canada
May 31, 2011
"Nothing lasts forever but the earth and sky" -- Kansas, 'Dust in the Wind'
Hi, Chris. In normal and proper application, Galvanized surfaces may take on a rust stained look relatively early on because of the iron content in the galvanized coating. This is not indicative of true rusting, which hopefully does not set in for a few decades. But galvanized coatings can also get "wet storage stain", which is white and crusty, and not considered proper. They can also get black spots, which some say is just an early manifestation of wet storage stain.
Please try your best to put your question into the full context of your own situation; otherwise the answers you get can be more misleading than informative. Thanks.
finishing.com
Brick, New Jersey
