Letter 34077
Stripping Zinc plating on sheet steel substrate [U.K.]
What is the best way to strip Zinc plating leaving the Sheet steel substrate in a condition where it can be re-plated ?
Peter Francis
Design Engineer - Chelmsford, Essex, UK
Immersion in a hot caustic solution or room temperature hydrochloric acid will remove the zinc. Your elecroplating contractor should be able to do this prior to replating.
Dougie Lightfoot
- Scotland
Dear Reader: please choose what you want to do--
I want to answer or follow-up on this subject publicly (in non-commercial fashion).
My company is a supporting advertiser at finishing.com and we want the contact information to reach the inquirer privately.
I want to post a new question or inquiry of my own on a different subject.
