HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 34074
Electrolite for electro-etching Sterling Silver
Hi...
I would like to electro-etch sterling and fine silver. In the past I have etch the regular way but didn't like the undercuts so we built an electro-etcher with instructions from a knife making site. Since they are etching steel, I need to find a different electrolyte to use with the silver.
Someone suggested phosphorus but I'm not sure how to buy or use this. I tried Coke and I tried salt. I'd like to use something that is as safe as possible but will still give a good etch. Do you have any suggestions?
Judith Bastienjewelry maker - Niagara Falls, Ontario, Canada
You can use 5% silver nitrate solution(add few drops nitric acid), or very diluted nitric acid.
Goran Budija- Zagreb, Croatia
