Letter 34052
Manganese phosphate coating on steel for
finishing steel objects
I would like to get a recipe for a manganese phosphate coating for
steel. If someone perhaps can explain me the actual chemical actions
taking place on the surface.
I've learned that there are many applications such as: 1 high wear
resistant and 2 better resistant against corrosion and a nice finish
3 as a pre-treatment for painting etc. Is there a big difference in
the recipe and chemicals ? The one I'm most interested in is
protection against corrosion and finish.
Jan Van Velde
hobbyist - Kesteren, Netherlands
You can use next solution:
25 gm phosphoric acid
1,5 gm manganese dioxide
1 lit water
Boil your objects 2-4 hours.
you must oil,lacquer or wax it!
(according to
Angier:Bluing
and Browning of Firearms)
- Zagreb, Croatia
Jan Van Velde
Manganese phosphating formulations contains basically a manganese
salt, phosphoric acid and an accelerator. Deposition of manganese
phosphate coating is normally performed at very high temperatures of
the order of 95 deg.C for a period of 30-60 minutes.
It is a conversion coating process and involves the dissolution of
the base metal which subsequently forms part of the coating. In
manganese phosphate coating the species that deposits on steel is
manganese iron phosphate and hence requires a large amount of metal
dissolution so that the formation of manganese iron phosphate is
possible. This is the reason for the requirement of high operating
temperature and higher processing time.
Manganese phosphate coating offers good wear resistance. It can
retain oil and lubricants and improves the scuffing resistance.
Manganese phosphate coating with higher coating weight offers good
corrosion resistance. Impregnation with oil further improves the
Zinc phosphate coating is mainly recommended as pretreatment
coating for painting.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
My company conducts manganese phosphate coating to carbon steel
pipe. We use heating element to heat the bath where the pipe coating
carried out. The problem is after the coating maybe for a week the
heating element covered by sludge. The workers usually remove the
sludge from the heating element by hammer ( mechanical). It doesn't
only remove sludge but also cause damage to the heating element (
made from stainless steel ). So...How to remove the sludge without
causing damage to the heating element ?
Dodi Syafardi
- Cilegon, Banten, Indonesia
Ed. note: Letters 11465 and
5142 address this issue in some depth,
Dodi. Patient use of our search engine will uncover still more tips
on this subject. Good luck.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
