Letter 33084
Cleaning brushed aluminum flag poles
Sirs, I've been given the task of cleaning three(3) flag poles
with brushed aluminum finish. Each pole is @ 30 feet tall.We can
reach these poles top to bottom as we have use of a cherry picker.
Each pole has black marks from the ropes and also oxidation. Please
advise me on the best way to clean them or should I consider painting
them.
Thank you in advance.
John T
Painting - Toms River, New Jersey
I also have been given the task of cleaning an old brushed
aluminum flag pole, it is oxidized and has algae covering the first
5-7 ft from the ground, I can access the entire pole what should I us
for best results
Ric Patterson
Facilities Maintenance Division
City
RIC P
- WASHINGTON
- ^-- I want to
contact
this person
and my company is a
supporting advertiser of finishing.com
I too am cleaning aluminum poles of graffitti, posters, tape and
mold. I'm using l
lacquer thinner [link is to product info at Amazon] and a
scraper knife as well as SOS pads. They shine up real good with a bit
of elbow grease.
Sam Smith
- Halifax, Nova Scotia
February 26, 2008
Information on cleaning an aluminum flagpole
Martin Breitinger
- Mansfield, Ohio USA
- ^-- I want to
contact
this person
and my company is a
February 26, 2008
First, get a very tall ladder . . . :-)
Seriously, Sam's idea is probably as good as any. There are
commercial aluminum cleaners available at your hardware store, but I
don't see where they do much. I would urge you not to use anything
with hydrofluoric acid, as this is just so dangerous that it deeply
frightens professional metal finishers. You could try
aircraft stripper [link is to product info at Amazon], which is
noxious stuff but not as bad as the HF. After you've cleaned it you
may wish to clearcoat it. The clearcoat not only protects it, but can
often restore lustre by offering a smooth surface instead of a rough
surface. If it looks good when wet, it will look a lot like that
after clearcoating. Good luck!
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- Post a
new question or inquiry on a
different subject.
