Letter 33082
Zinc plating defects - quality of surface
We had a housing made from cold rolled carbon steel sheet and zinc
plated with yellow passivation.
After opening it recently from the package after three months we
noticed some fungus like white powder on the surface of the sheet.The
housing was packed in an air tight polyethelene sheet. I would like
to know the technical reason for this problem.
Ravi G
sa graphics - Bangalore, Karnataka, India
It is, most likely, white corrosion product due either to the poor
chromating job or the entrapped moisture (source/origin of which will
need further investigation). A chemical analysis/characterization of
white powder found on the part will be helpful in determining the
root cause.
Raj Singh
- Cleveland, OH, U.S.A.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
