finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 33080
Autophoretic topcoats research
Dear Sir:-
I need to evaluate my ACC866 research on the autophoretic coating system.
it's common that acc866 only deep blue or black colour and the only top coat approved is the polyurethane.
1- I have got inorganic water base material which is sensitive to ACC866 surface and give golden metallic colour when applied on the hot ACC surface the problem of this material that it is not stable and need to be fixed on the surface, it's improve some properties of the coated surface .
2- the real problem I have solved in my line is when I got a non homogeneous colour on the surface I add new rinse bath with some material which give the final product a homogeneous surface and very good performance . In fact I did not check up the salt spray test after my addition .
Now I need to evaluate of my research and the disadvantages. thank you for help
Khaleed El Deeb
   autophoretic coatings
6October, Cairo, Egypt
