finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 33079
Problems in mechanical plating
I am in a mechanical zinc plating plant. Zinc is plated over iron.We use a green liquid for creating a copper flash while plating zinc. But, Most often the components( iron), become black in colour as soon as the addition is done. Also,sometimes the copper coating never occurs an the components remain black,why?
We use one white chemical and the label says it contains stannous chloride,why is a tin flash and copper flash needed?
Sometimes if plating does not occur I used to add a little more tin flash in between the zinc powder additions and if it is done immediately the plating occurs, is it because of tin or might be any other additive that is present in the chemical?
What other problems do occur while plating mechanically and what are all the causes and the ways to overcome?
Shanmugam P
Brakes India Limited. - Chennai, Tamil nadu, India
Don't these "green liquid" and "white chemical", etc., come with technical data sheets that explain what they are, how much is needed, and how to analyze the solutions and troubleshoot the problems, Shanmugam? It is very difficult from this distance to hazard a guess as to whether you've added too much "green liquid" or too little. You seem to be describing a whole host of uncontrolled process variables. Good luck.
finishing.com
Brick, New Jersey
What is happening is that your media is contaminated with unplated zinc. When you attempt the immersion coppering process, what should happen is that the copper in the acidic medium displaces the iron or steel. What IS happening is that unplated zinc is plating on the part prematurely; when you add the coppering compound, the copper is reduced to fine metallic form (black) and, typically, adhesion suffers. If you strip your media from unplated metal with sulfuric acid or hydrochloric (muriatic) acid, the problem will go away. The immersion copper deposit and the (electroless) tin deposit are necessary for adhesion.
Tom Rochester
Plating Systems & Technologies, Inc. - Jackson MI
