HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 33068
Teflon coating of heat exchangers
I am doing my project on coating a heat exchanger with Teflon to make it corrosion resistant. The heat exchanger will be used in oil & gas or petroleum industry.
The conditions are: approx. 160 o C temperature, untreated water, H2S gas inside the tube while water is outside the tube to cool the gas. The pressure inside the tube is around 1282 psi. The heat exchanger weighs around 4.5 ton.
Could anybody please tell me whether I can use Teflon coating for such application and if I can then what process I can use? Thanks Cathy
Catherine HuntStudent - Auburn, Maine, U.S.A
For safety reasons it would not be a good idea to coat pipes with a thin layer of Teflon which might separate from the basis and loose its imperviousness and expose the metal. Thick coatings as well as solid Teflon would impede the primary function of a heat exchanger due to the poor heat transfer of all plastics. In summary, I think you selected a very difficult application or project.
First of two simultaneous responses -- ++++
If you are allowed to change the focus of your assignment, anodized aluminum makes great heat exchangers, especially in water cooled applications. "The Surface Treatment and Finishing of Aluminum and Its Alloys" goes into the details of why it works so well; second volume, mid-way or so...
The oxide coating formed by anodizing would also increase corrosion resistance.
Jim Gorsich Accurate Anodizing Inc. Compton, California, USA |
Second of two simultaneous responses -- ++++
Well...some companies are making all-Teflon heat exchangers. I wonder how they dealt with the heat transfer issues. But I think if coating is thin enough then heat transfer wouldn't be a problem. And if coating is done well then it will protect it fairly.
Catherine Hunt- Auburn, Maine, U.S.A
| August 7, 2010 I am a final year chemical engineering student. I have selected this topic for my seminar in my college. I found some information about this topic in the magzine "Chemical Engineering World", page no.46. I hope it will help you.... Pranav Kulkarni- Miraj,Sangli,Maharashtra,India |
