Letter 33049
What Rockwell hardness from anodizing?
Can someone familiar with anodizing process tell what type of
Rockwell hardness can be achieved? How much can one increase the
hardness of an aluminium workpiece surface?
Look forward to some response.
Morgan Chetty
sait - Calgary, Alberta, Canada
First of two simultaneous responses -- ++++
You can not get a true Rockwell hardness on anodize, You need a
microhardness which you can only partially equate to a Rockwell.
Reason, the anodize layer is a ceramic and the aluminum will give way
enough, causing the ceramic coating to fracture and give you a low
reading. If you would tell us what you intend to use this added
hardness for, someone(S) might be able to give you an idea of what
would work or options.
Second of two simultaneous responses -- ++++
Although Rockwell is not typically used in measuring hardness
(normally, one would use a taber abrader) on an anodized surface,you
can expect 60-65 Rockwell on a decent hardcoat.
Marc Green
anodizer - Boise, Idaho
To paraphrase from Wernick Pinner
and Sheasby:
The usual methods for testing hardness, like Brinell or Vickers,
isn't applicable because the give the hardness of the basis metal.
They then go on to say that there are complications using Rockwell as
well, and that the most appropriate methods are tests of abrasion
resistance.
All that being said, the final abrasion resistance is affected by
a bunch of different factors, most of which will be controlled by
your anodizer, but alloy selection plays a part as well.
If everything is done correctly, and you choose an alloy that
performs particularly well, the final abrasion resistance can exceed
that of tool steel.
Mind you though - I'm a type II anodizer, not a hardcoater. My
understanding may be a bit off, someone else on this site may be
better able to answer.
Now, if you had a question about bulk anodizing of fasteners...
What are some of the factors that would make the hardness change
between parts? the base material, plating bath or amps? or all of
above. What spec. calls out for hardness testing to be done to? I am
getting all kinds of info from the net and each one is different as
for as the hardness requirements. HELP!
Thanks Beth
Beth
- Dayton, OH, USA
Ed. note: Full name on your followup please, Beth. Thanks
Pretty much all of the above plus the temperature of the acid bath
as well. When anodizing in sulfuric acid there are two competing
processes going on - the oxide coating is building due to the
electricity being applied to the parts, and the oxide coating is
being dissolved due to the action of the electrolyte. Factors that
discourage the dissolution would favor hardness; this would include
lower temperatures, lower acid concentrations, higher current
densities...
Also, alloy selection is going to play a role as well, but I'm not
certain which alloys end up harder than the others.
One last variable, sealing the part decreases hardness - but is
necessary if you are going to dye the part.
With regard to specifications, the most often referenced anodizing
spec is Mil-A-8625 [link is to spec at TechStreet] which
specifies an abrasion resistance test as follows:
"4.5.5 Abrasion resistance. Test specimens, prepared In accordance
with 4.3.3.2.4, shall be tested in accordance with Method 6192.1 of
FED-STD-141 using CS-17 wheels with a 1000 gram load. The wheels
shall revolve on the anodic coating at a speed of 70 revolutions per
minute (RPM) for 10,000 cycles. The abrasion wheels shall be refaced
at least once every 10,000 cycles. The wear index shall be determined
after the 10,000 cycle period by dividing the weight loss by 10. The
wear index shall meet the requirements of 3.7.2.2."
But it doesn't specify hardness test per se.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
