HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 33045
Safe removal of clear coat from brass
++++I am an contractor working on brass stanchions which are used to section off areas of high traffic. the total number of stanchions is 200. The Stanchions have an clear coat on them I need to remove the clear coat without damaging the brass so that the brass can be polished and clear coat reapplied I do not know what method to go with please help.
Derrick Fudgespecialty coating - Biloxi, Mississippi, United States
You can use any solvent based paint stripper!
Goran Budija- Zagreb , Croatia
You need to know what the clearcoat is. There are several possibilities, and each requires a different solvent. The solvents of choice are all flammable and some are mildly toxic. This is not a job to give an untrained worker a bucket of solvent and a rag.
James Watts- Navarre, Florida
Have you considered using dry ice blast cleaning. Clear coat can be removed without damaging the surface of the brass and you will have no clean up.
James Becker- Cleveland, Ohio
