Letter 33035
Cobalt electroless bath does not work
with EDTA as complexant
Hi, I am doing a cobalt electroless plating process with pH 8.85,
sodium hypophosphate as a reducing agent. Also, I use EDTA as my
complexing agent, however, no plating is observed on my Silicon
substrate. Instead, there is a distinct blackening of my substrate.
Any thoughts on this? The plating solution works with the same
concentration of sodium citrate and malic acid as complexing agents,
but not EDTA.
Su Wen Yu
student - Singapore
It would appear that your cobalt is too strongly bound to the EDTA
to get it to plate out. Possible areas to look at are weaker EDTA
solutions, a different pH and higher temperatures. Will it plate out
on a clean piece of steel??
I would like to do electroless plating of a Cobalt-Phosphorus-Iron
alloy. However, when I add Iron sulphate to my electroless Cobalt
bath consisting of hypophosphite, sodium citrate, boric acid and
ammonium sulphate as well as cobalt sulphate, no plating occurs at
all. The cobalt plating bath works without the addition of iron
sulfate. May I know of a suitable electroless bath which i can use? I
am getting desperate, thanks a lot.
Su Wen Yu
student - Singapore
First of two simultaneous responses -- ++++
Su wen Yu, I am a bit confused. In your initial submission you say
you cannot get your electroless cobalt bath to deposit when you use
EDTA as the complexant; I am not surprised because EDTA is about the
strongest complexing agent you can find. To get the cobalt bath to
work, you need a milder complexant. The most common ones are
lactates, citrates, glycollates or maleates. I would suggest trying
citrate.
You then go on to ask about a cobalt-phosphorus-iron system. Is
this a different problem, or is it a follow up to the first one?
Alloy deposition is always difficult and electroless alloys are most
unusual. The reduction potentials of cobalt and iron (II) are quite
similar (-0.28 and -0.403V respectively, but the water complexes have
slightly different strengths and they inhibit the reduction of cobalt
in favour of iron; that is why you get reversed preferential
deposition of iron in an electrolytic system. If you use Fe(III), the
reduction potential is stated as -0.037V, but the reduction goes
through an Fe(II) step, so there is no benefit in using ferric ions.
Furthermore, Fe(III) is not a good start for any plating solution.
The alloy you want is quite esoteric, so I suggest you do a good
literature search before seeking the easy way by asking for help on
the Internet
R&D practical scientist - UK
Second of two simultaneous responses -- ++++
The temperature I use is 80 degrees celcius, which is the normal
plating temperature. Due to the nature of my project, I am comparing
the effect of different chelating agents on the plating of cobalt. I
use the same functional group to metal ion ratio for each chelating
agent. Will this still result in overstability of complex ion? also,
i noticed that many edta solutions use hydrazine instead of
hypophosphite as a reducing agent, can this also be a reason?
Yu Su Wen
This is a followup to the first part. Part of my project is to
change chelating agent and observe the different effects on plating.
The other part is to incorporate iron into the plating and observe
how different concentrations of iron affect the plating. Citrate and
Malic acid have worked perfectly for my case, but EDTA does not. As
for the iron, I have read some texts and found that this is indeed
possible. Using the solutions provided in the text, I have made the
plating bath only for it not to plate at all. Upon addition of
exaltants like boric acid, plating does indeed occur, but at a much
slower rate.
Yu Su Wen
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
