Letter 33012
James Totter,
CEF |
Dear Mr. Holmes:
You need to be more specific in your question.
Hull Cell can be applied to many electroplating processes, with different purposes.
Oscar Infante
- Santiago, Chile
Applied current and testing time all depend on what you are testing in the Hull Cell. There are set conditions for different plating systems, details of which can be found in any reputable book that discusses the Hull Cell. Try The Canning Handbook. No-one can answer your query unless you say what you are doing.
Trevor Crichton |
How do you read the hull cell ruler? it is stated from the ruler
that it has 1, 3, 5 Amps. how much time should you use?1 min or
more?
We are currently using SnPb chemistry for ic packaging. i'm a bit
confuse as to how to read the ruler. i'm currently using 3 Amps 2
min. when i read the result using the ruler, i use the 3 amp portion
and multiply the Current Density by 2..is this right? we are using
10-20 ASD meco plating machine.
I hope you guys can answer this question the soonest. thanks in
advance!
Michael Tongson
semiconductors - Laguna, Philippines
Save
This Page (why?) - Home - ©1995-2009 finishing.com
