Letter 32089
Electroforming foil to a stepdown/recess
I am working in eforming of foils for smt. I am looking on how to
achieve different thickness on the same foil. What to passivate and
activate the nickel with?
Jane Munro
plating - Mississauga, Ontario, Canada
Passivation of the nickel can be achieved by dipping it in strong
solutions of sodium metabisulphite, sodium dichromate or potassium
permanganate. Activation depends on what type of nickel you are
using. If it contains any additives, you will almost cetainly need to
use a nickel strike. Changing the thickness can be done with screens
or robbers.
R&D practical scientist - UK
For manufacturing two step SMD Stencis you will need a two step
lithographie, that means first lithographie on your mandrel, then
nickel deposition, then the second lithographie covering the area
where you want to have the thinner regions. Activating the nickel is
not easy, as a nickel strike will damage the resist from
lithographie. What you can use if you have an brightener in your
plating electrolyte is a mixture of iodine, iodid and sulfuric acid.
Good luck,
Marcus Hahn
- Lucerne, Switzerland
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
