HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 32050
Turning Polished Chrome finish to a Satin Nickel
++++Q. I have read several of your letters regarding stripping chrome or chrome plating. I have a kitchen faucet which has a bright chrome finish. I image it is of the chrome plating technique. I would prefer the finish a less shiny nickel look. I have used muric acid to age copper for architectural projects. Would the technique be similar? My method was to pour some acid on the metal and allow it to sit for various amounts of time depending on the results I wanted. Would I proceed in the same direction with the chrome?
Richard Wiehearchitect - Tucson, Arizona, United States
++++ +++++ Q. I've read several messages regarding the use of muriatic acid on polished chrome. They suggest that it will quickly dissolve the chrome, and leave nickel. However, my goal is not to eliminate the chrome--I just need to create a more matte finish, so that one of my overflow/waste covers will match the other brushed chrome fixtures. Would I still use muriatic acid? If so, would I just use it for a shorter period of time? Is
muriatic acid [linked by editor to product info at Amazon] readily available to the public? Is any other method preferable? - Los Angeles, California
+++++A. Hello Bret. You probably will not achieve the result that you want that way because it's not something that is done within the chrome layer, which is only a few millionths of an inch thick. Depending on the particular effect you are looking at, it was done either by brushing a pattern into the substrate before plating, or by using a finicky nickel plating solution that includes special ingredients to satinize it.
People are familiar with painting things, and then they see or hear of school science experiments in electroplating, and begin to think that this is something they can do at home, but realistically it isn't. I'm not here to discourage the very serious hobbyist who wants to try it after years of experience, but electroplating is mostly a high-production industrial science, and you probably won't be able to do what you want. A plating jobshop can do it for you (although getting an exact match is tough), but you may find it cheaper and more productive to hunt around for a new one that matches. Good luck.
finishing.com
Brick, New Jersey
January 23, 2012 |
