HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 32048
Need steel tube cleaning, polishing, coating
seeking local-ish shop to convert steel tube, presently with an abundance of mill-scale and other oxidation up to a level suitable for powder-coating. A shop that could perform both operations would be preferred.
Presently, the engineer is concerned that the oxidation is such that a "filler" process may be required, a thicker baked enamel to fill/hide the scarring.
If you are aware of someone in BC canada, Washington State, possibly Idaho? that could solve our dilemma, would be greatly appreciated.
quantity 46,000 ft in 12 foot pieces. (7/8 inch tube)
John OdlumSecurity Systems - Richmond, BC, Canada
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
