letter 32046
Robert H Probert Editor's
note: |
YOU CAN USE WALNUT SHELL GRIT OR GLASS BEAD FOR THE PURPOSE OF BLAST CLEANING YOUR PRODUCT.
RAJESH PATEL
- JAMNAGAR, GUJARAT, INDIA
You should also be aware of the pass through semi-automated systems similar to wire drawing; however, you use power brushes.
AF Kenton |
The glass small spheres at 0.2-0.5 mmdia or larger if you find it.
Here in Romania will produce it.
Damian Dinu
- Constanta, ROMANIA
You may want to consider using Stainless Steel cut Wire Shot. The hardness generally ranges between 52-58 Rc. The use of this media will eliminate Ferrous contamination from you cleaning process.
Michael Deakin
- Buffalo, New York
Save
This Page (why?) - Home - ©1995-2009 finishing.com
