Letter 32040
Pinholes on an ENP 50 microns layer
I'm a technician of an italian metallurgical laboratory. I'm
requested to evaluate the quality of an ENP (thickness 50-60
microns). The plating has been applied with a traditional process
over a spherical steel surface and complies with all the specified
requirements (adhesion, hardness, etc.), with the exception of the
look of the Ni-P layer, which appears almost totally affected by very
little pinholes (like "needle-tips"). Your opinion would be greatly
appreciated about the source of such a defect (hydrogen evolution?)
and the impact of it on the performance of the protective layer.
Could the defect be really detrimental for the behaviour in service
(contact with water) or it can be considered only an aesthetic
problem, being the pinholes not penetrating the coating to the base
metal? Could the ferroxyl test be significant? Is there a
non-destructive system (apart from the observation with a
magnificator) for evaluating the extent of the defect (for examples,
replicas)! ?
Finally, if it is a sign of an uncorrect process condition, which
are possible reliable interventions? Thanks a lot for your attention.
Best regards.
Fabrizio Fantechi
metallurgical testing and control lab - Carpi, Modena, Italy
If the pits are very small and universally
over the surface of the part, they are probably the result of an
organic contaminant (like a solvent) in the plating bath. If the pits
do not extend through the coating to the substrate, a ferroxyl test
will not reveal them. The pits may or may not effect the performance
of the part. If the EN coating is not attached by the "water", then
the pits probably will not get any deeper. However, if the "water"
does corrode ENP, then the life of the coating will be much
shorter.
The substrate has been ground or lapped, an
alternative cause of the pitting might be embedded media on the
surface which is initiating small gas pits from hydrogen
evolution.
Ron Duncan
Palm
International, Inc. -
LaVergne, TN
Ed. note:
It is our sad duty to alert the readers to the passing
of Ron Duncan on Dec. 15, 2006. For those who would like to
know more about him, a brief obituary opened
Update No. 13 of our
Metal Finishing Industry Update Podcast.
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
