Letter 32038
Plasma ion nitriding plus cryogenic
Dear Sirs,
Is it necesary to harden the steel before doing plasma ion
nitriding to reduce the hardness difference between the surface and
inner core.
Which of the following will give better surface:
Hardening+PIN+Cryogenic or Hardening+Cryogenic+PIN
Raja Sundaram
consultant - Coimbatore, Tamilnadu, India
Dear sir,
I want to know how and why ion nitriding is better than gas
nitriding..
regard..
Noorul Hidayah Shaiful
Alam
University Technology Malaysia - Skudai, Johor Bharu, Malaysia
Dear Noorul,
Plasma Ion Nitriding(PIN) scores over gas nitriding and other
conventional nitriding in the following areas:
· Lower processing temperatures: This factor signifies lower
dimensional distortion and more control on the formation of
undesirable metallurgical phase.
· Almost zero contamination: With the use of vacuum, chemical
contamination due to the presence of atmospheric oxygen, moisture of
hydrocarbon etc. is eliminated.
· Faster treatment cycles: PIN cycles may be as short as 15-20
minutes or 6 to 8 hours on an average compared to the 80 to 100 hours
required by gas nitriding.
· Total control over the nitrided case: All conventional
nitriding processes call for an additional lapping/grinding operation
to remove the brittle 'white layer'. In comparison, PIN is the only
nitriding process, which offers total control over the composition of
the nitrided case.
· Lower Costs: Due to shorter treatment cycles, greater
reproducibility and an almost zero rejection rate due to tight
process control, PIN works out much cheaper. PIN can act as a final
hardening cum finishing operation, thereby reducing manufacturing
costs and can replace costlier materials used conventionally.
· Augmenting the metallurgy: In high wear rate components such
as mining, earthmoving or construction equipment. PIN can raise
surface hardness from 65-68 HRC obtained traditionally to 72 plus HRC
at a small extra cost.
Raja Sundaram
- Coimbatore, India
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
