letter 32035
Will deionized water harm copper tubing
in a heat exchanger
At our manufacturing facility we have heat exchangers that cool
our induction annealing coils. It has been recommended from the
manufacturer of the coils to use distilled water. We have DI water
readily available on plant, but a question has come up as to whether
the DI water will cause any substantial damage to the copper tubing
of the exchanger. Has anyone come across any problems of this nature?
Thanks for any info.
Kyle Maxeiner
Manufacturing - Independence, MO, USA
First of two simultaneous responses -- ++++
DI water is corrosive and will slowly corrode the copper piping in
your system unless you also control the pH and add a corrosion
inhibitor. On the plus side, distilled or DI water will not scale up
the heat exchange surface. You should probably contact a chemical
company that supplies boiler and cooling tower chemicals for their
advice.
Lyle Kirman
water treatment systems - Cleveland, Ohio
Second of two simultaneous responses -- ++++
Depending on the quality of the water you have in your DI loop, it
could be "clean" enough to be highly corrosive. The same can be said
for softened water too.
As these types of water have been chemically stripped of certain
ions that would otherwise make them less aggressive, they can attack
exposed copper surfaces and etch or corrode them until you get to a
failure point. Distilled water is not as corrosive, as it is simply
condensed water, and essentially more balanced chemically than DI.
Tom Baker
wastewater treatment specialist
Warminster, Pennsylvania
++++++ -- this inquiry appended
to existing thread by editor
Can you run D.I. water through copper piping?
Grant Krakowski
Optical - Dallas, TX
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
