HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 32023
Achieving roughness on cp titanium
I am working on titanium cp to make it dull and rough by etching with Hydrofluoric and Nitric Acid bath. What are the bath conditions--acid concentrations, time and temperature?
Thanks a lot.
Rosario Ardiachemist - Eboli, Salerno, Italy
Nitric/HF will probably brighten titanium. To dull the surface use a mixture of 8 oz/gal Potassium Hydroxide + 5% Hydrogen peroxide at room temperature. This will require 1 to 4 hours to produce a dull etched finish.
Jeffrey Holmes, CEF - Spartanburg, South Carolina |
I am working with the Titanium cp grade 2 and I have realized the etching with a mixture of 8 oz/gal Potassium Hydroxide + 5% Hydrogen peroxide at room temperature. I have got brown surfaces that I presume to be titanium oxides with impurity of others metal, like iron. I would like to make more biocompatibility the surfaces by modify titanium surfaces in titanium oxides particularly TiO2. What kind of treatment can I test? Tanks in advance.
Rosario Ardia- Eboli, SA, Italy
I have not seen that problem after etching with KOH/H2O2 mixture. Will a simple high pressure remove it?
