Letter 31094
Why is there sometimes copper residue
after stripping EN?
I have recently been experimenting using room temperature
electroless nickel stripper to take nickel plating off of old nickel
plated steel horse bits and spurs. The solution seems to work well
and the plating on some pieces comes off clean as a whistle after a
few hours in the solution. however some pieces have a copper coating
or residue on them which does come off with a little elbow grease,
light sanding, and buffing but is difficult to remove from moving
parts and crevices ect. My question is: What causes this copper
coating? Do I simply need to soak some pieces in the solution longer
to get them to come out completely clean down to the steel or is
there some other reason that certain pieces come out clean while
others have this copper coating? if so how can I avoid this copper
residue or what can I do to take the copper off without sanding ,
buffing ect. Will longer soaking help or is the copper coating just
normal with this type of stripping solution?
Matthew Jones
hobbyist - Dallas, Texas, USA
Strippers are deliberately designed to remove only one metal. Most
likely, the parts that came out 'clean' were electroless nickel on
steel. The other parts were probably copper and nickel plated before
the electroless nickel plating, and your stripper doesn't remove the
copper. You would need to follow the nickel stripper with a copper
stripper.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
