Letter 31084
Silver will tarnish in SO2, especially if it is moist. If the tarnish layer is thick enough, it will result in an electrically insulating layer that could result in an intermittant electrical fault. Removal can be achieved by polishing with a suitable silver polish, but it is all horses for courses.
Trevor Crichton |
Yes, the Silver tarnish does cause problems in switches when used for low voltages; that's why Gold is used in low voltage electronic switches. A higher voltage (24 to 50 Volts if I remember correctly) is able to 'punch through' the tarnish and the switch operates normally. And at higher currents, the small amount of arcing tends to clean a Silver contact but corrodes a Gold contact rather rapidly.
Tom Gallant
- Long Beach, CA USA
I've seen some telegraph key makers enclose acid free polishing
paper strips to periodically pull through closed silver contacts.
Most of the contacts I deal with are solid coin silver rather than
plated and I just take my
Dremel [link is to product info at Amazon] cloth buffing wheel
with a dab of polish paste on it and hit them a couple whacks.
Usually, I only have to do that to a key I just got from someone that
never ever cleaned the contacts on and I never have had to reclean
one I buffed to a mirror finish. Silver is a better conductor than
gold by the way, but gold doesn't oxidize like silver does. Some
makers of keys wised up and made what wss described as a "wiping"
contact that cleaned itself with each closure. I am more concerned
about dust giving me intermittant contacts than oxidation on
silver.
Now, carbon from arcing on contacts can really mess you up.
Dealing with high voltage and with RF goes a bit deeper than I am
prepared to go with this response.
George D. Ballentine
- Orlando, Florida, USA
Save
This Page (why?) - Home - ©1995-2009 finishing.com
