Letter 31069
How to allow for cooling of copper in
vacuum after annealing
Can anyone please let me know that how the cooling can be done in
inert atmosphere( detail process) or in vacuum so as to avoid the
blackening.
MITESH BATRA
enamel copper wire - INDORE, MP, INDIA
The only way to cool parts in vacuum is by rediation or mechanical
heat transfer, both are very slow. Mechanical heat transfer requires
good physical contact and water cooling of the holding fixture. The
other method used post vacuum heat treating is blowing cool, neutral
gas such as nitrigen, argon or helium. It becomes expensive unless
you have means to recover the gases. Blackening may be the result of
moisture in the neutral gas. It needs to be dried using gas dryers.
Mandar
Sunthankar
- Fort Collins, CO
Usually nitrogen or argon (70-90 bar)is used for quenching. You
need to careful with the dew point of nitrogen and argon used (-60F
or better). Any presence of moisture will affect the load.
Bala
- Winnipeg, Manitoba
Dear Reader, please --
- Answer or follow-up on this
subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a
different subject.
