Letter 31060
Rusting Pickled 316 Stainless Steel
I have castings out of 316 ss material which have been pickled
post heat treatment, which are said to be rusting on the field.
There's also an observation that pickled castings are being tested by
immersing them in water in glass containers which are said to be
rusting after 8 hours in the water. the castings are small weighing
less than 1# what could be causing this? I never ran into this
problem before. I have not changed my process, I have taken care not
to contaminate these castings with any sort of iron or carbon base
material. I have done no further processing after pickling them. Any
suggestions or ideas of what can be causing this? I fully trust my
pickling source. Thank you.
Mr. Manuel Gutierrez
Steel Foundry - Los Angeles, California, USA
What chemisty is being used to pickle the parts? Some people use
HCl for this, which is very bad for the stainless steel.
When you make castings of 316ss you will end up with alloy changes
on the surface. Sometimes it takes a lot of passivation to get the
surface corrosion resistant.
While solution annealing pl.use as much as possible argon
atmosphere to reduce Cr depletion from the surface which will reduce
the pickling load.
Check the contamination of iron particle in the complete
processing.(shot blasting,brashing grinding etc)
Even while casting you can try rinsing the mold by argon gas which
will reduce the CR depletion from the casting surface.
Youcan try this by grinding by proper tool the existing casting
surface to a depth to ensure the depleted layer and subject such
groud surface to test for rusting.
Best of Luck
N.N.Jena
NANDA NANDAN JENA
S S tubes & castings - Ahemadabad, Gujarat, India
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
