Letter 31034
Can we improve our tin plating to 240 hours
Salt Spray?
Can Pure Acid Tin obtain 240 hours in Salt Spray Tests? How can we
archieve this requierement? Our client request this and normally we
plate to 24 hours, but not 240. The part is made of steel and
processed in barrels, we don't know if we need to apply an undercoat
of copper or nickel (thickness?) and what Tin thickness, as well as a
chromate or sealer. Please advice regarding the best procedure .
Thanks for your help.
Sergio Enriquez
Job shop - Guadalaja, Jalisco, Mexico
I haven't received an answer to this question (31034)
Sergio Enriquez
Job Shop - Guadalajara, Mexico
Dear Sergio,
Yes, it can resist 240 h in SS according
B-117 [link is to spec at TechStreet]. It depends on
thickness and porosity of the tin layer. Tin will protect steel only
if it is pore-free. Where that is not the case, the iron becomes
anodic and strong corrosion follows. According to ISO 2093, 1986
coatings are classified in four categories; group 4 extremly
demanding conditions, group 3 demanding cond., group 2 moderate cond.
and group 1 mild cond. Over steel the following thicknesses are
required : 30, 20, 12 and 5 micron. Corrosion resistance can be
improved by a copper-strike interlayer.
Test for porosity with Kesternich test (enclosed in ASTM B 545) or
ferroxyl test, plate some test parts and check corrosion resistance
in the SS- chamber to set up process parameters.
Danny Neidel
- Guadalajara, Jalisco, México
Dear Danny,
Thanks for your help. I'm not familiar with ISO 2093, 1986 what SS
resistance is expected for each service condition 4, 3, 2 and 1 with
the thicknesses mentioned?
We plated the Steel part with copper, then 8 microns of Tin and a
chromate and got only 144 hours? Any recomendations? What about the
use of sealers?
Gracias por tu ayuda,
Sergio
Sergio Enriquez
Job Shop - Guadalajara, Jalisco, Mexico
Hi Sergio,
In the standard mentioned you need to plate 30 micron(group 4), 20
micron(group 3), 12 micron(group 2) and 5 micron(group 1). To reach
240 hours in SS over steel you have to plate at least 20 micron.
Chromates avoid staining in the parts, but it doesn't improve really
corrosion resistance. If it is permitted (parts are not soldered
after plating), you can use a organic sealer or laquer. That is easy
to make for rack parts, small parts in barrel tend to stick with each
other. A organic sealer improves corrosion resistance 2-3 times,
commercial products are available from local vendors.
I hope that's helpful.
Saludos
Danny Neidel
Danny,
Thanks for your help. I´ll try with the 20 microns and a
sealer.
Thanks again
Sergio Enriquez
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- Post a new
question or inquiry on a different subject.
