HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 31017
Satellite designer needs outgassing data for Iridite 7p
I am planning to use Iridite 7p per Mil-C-5541 [link is to spec at TechStreet] to coat my copper waveguide. The issue is that those waveguides have to go in a thermal vacuum chamber so the outgassing of the coating must be low.
Does anyone know if that coating has already been used for a space application or/and where I could find some outgassing data (I went to the NASA website http://outgassing.nasa.gov but nothing is there).
Best regards,
Franck Bordesatellite designer - Montreal, Quebec, Canada
