Letter 31000
Powder coated steel corrodes from
smallest scratch [India]
Currently we are Powder coating our SA-105 forgings to avoid
corrosion, but what we are seeing is, once any small scracth is done
on the surface it starts corroding very fast. Is there any other
surface treatment which can really give good results compared to
Powder coating. I heard about Cadmium coating and Tin-Zinc coating
are they good enough even with small scratches and operational marks.
Plz consider we are into water treatment business.
Bhanuprakash A R
designer - Verna, Goa, India
Powder coating is only a barrier protection in corrosion terms.
When the barrier is perforated, the protection does not exist. A
better step is to add electrolytic protection. Means to do this would
include zinc plating zinc metal spraying and hot dip galvanizing.
Questions to consider include: What protection do you need? (zinc
plating offers much less protection than galvanizing for example) Is
colour important? (plating or galvanizing has no real colour choice,
but could be overcoated with powder coating for example, though watch
that adhesion is Ok by proper pretreatment, such as zinc phosphate
after suitable etching)
Geoff Crowley
galvanizing &
powder coating shop
Glasgow, Scotland
Mr A R,
How bad are these items being abused that the coating is being
removed? I would suggest double checking the cleaning, cure,
thickness and paint formulation to make sure you have what you need
for your application. If all of these things are in line, the parts
should be able to take a pretty good amount of abuse before they
fail.
Sheldon Taylor
supply chain electronics
Wake Forest, No. Carolina
Dear Reader: please choose what you want to do--
- I want to answer or follow-up on this subject
publicly (in non-commercial
fashion).
- My company is a supporting advertiser at
finishing.com and we want the contact information to reach
the inquirer privately.
- I want to post a new
question or inquiry of my own on
a different subject.
