HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 30051
Need to patch up the leakage in vacuum chamber
++++There is a Crack observed in the vacuum chamber at the welded joint. The chamber vacuum is thus not able to drop below a particular point. I was wondering if I could patch this temporarily with any sort of material and also not affect the process of degassing in the process. Are there any sealant or paste used for this application?
Satish Ailmaintenance personnel - Etobicoke, Ontario, Canada
