HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 30046
Surface coatings for carbon fiber gun barrels
I am the holder of patents relative to carbon fiber gun barrel construction and looking for coating options for consideration. The barrels have a steel liner as the bearing surface and then are built up to finish diameter with carbon fiber mat material as specified. I would like to know what coating options exists for both cosmetic and practical applications. Thank you. David S [last name deleted for privacy by Editor]firearms consultant - Vancouver, Washington ++++ From my experiences with carbon fibre it doesn't need a coating, the bonding resin gives it good mechanical qualities. For appearance maybe try an epoxide with pigment added to change the color. A final layer of woven carbon to give it the hologram/cats eye effect (I cant for the life of me spell the technical term for that effect), dyed kelvar for a final coating? Lately I've been looking into an abrasion resistant coating for a project I'm working on..the search has led me to epoxy-siloxane resins, and crosslinked polysilicate resin. used for high gloss and scratch resistant coatings. I've never worked it so I don't know much about it, have some on the way and will know more soon. I don't' know exactly what you are looking for so I'm just throwing ideas out there. We have a carbon fibre barrel on our little .22 used for plinking, I love it. Jason Aube- Flint, Michigan |
January 26, 2008
Two-part sports car or speed boat or custom motorcycle varnish exists, and one company even offers the clear two-part stuff in a special "spray paint" can in which you have to push a bottom plunger to mix two ingredients, then you get about six hours until the contents solidify in the can. The company is "Alsa Corp" which also sells all manner of thin decorative laminates for motorcycles and show cars (too thin to be durable, indent-resistant, or corner-peeling resistant etc.).
One other option that I have little experience with, but which should also be heat resistant is "Water Glass" which upon evaporation gives a true glass layer. It would not likely wet out into a smooth coating on plastic carbon fiber, but surface treatments exist (such as made for making glue stick to hydrocarbon plastics or nylon). These materials are available from McMaster-Carr. They also sell clear
Teflon heat shrink tubing.
Future Acrylic floor wax is actually pretty good stuff, and goes on so thin that you needn't worry much about how thick it goes on. It is removable with ammonia. It's used as an old model airplane canopy anti-scratch or scuff-coverup trick. Again, if it won't wet the surface, add some soap or pre-treat the surface with "Nylon" or
"Polypropylene" adhesion promoter liquids first. They are surface oxidants that quickly evaporate, leaving no residue.
A good car wax is Buffalo Milke, which comes in a spray-on/wipe-off bottle. One of those late night TV infomercial products, but it really works well to retain gloss and resist finger prints after a very easy
(non-buffing) application and cotton rag wipe or two. - New York, New York February 11, 2008 David
