finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 30042
Specs for bright dipping copper and brass
Are there any specifications out there for bright dipping copper and brass?
Bob R [last name deleted for privacy by Editor]
plating shop - Elyria, Ohio
Here we do Bright dipping of copper Terminals which are used in Automotive batteries.
The Process Flow is as below:
1. Cleaning : By means of Kerosene and Saw Dust
2. Rinse : Rinse the material by means of Raw Water
3. Solution Make Up: Ratio of 4:1:1 (4 Parts of DM Water : 1 Part of Nitric acid & 1 Part of Sulphuric acid all are commercial grade chemicals)Dip in the same for few seconds as the copper will melt in the solution its just a surfce preperation for the adhesion of PASSIVATION.
4: Rinse : Raw water Rinse Twice
5: Passivation : Yellow color as per u r requirement
6: Rinse : Raw Water Dipping once
7: Dryiing : any type of Dryer can be used
T.Dinakaran
T.DINAKARAN
- Chennai,Tamilnadu .INDIA
