HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 30033
Cracks in decorative copper-nickel-chrome plating
Why does copper Nickel Chrome (Decorative) plating crack?
Mustafa Bin TaibZinc Die-Casting - Singapore
If it is done right it does not crack, Mr. Taib! It sounds like something is terribly wrong, perhaps in the nickel plating step -- but you would need to give us something further to go on. Does it crack if removed before chrome plating? If removed before nickel plating?
We assume the substrate is diecastings since that is the industry you say you are in.
