Letter 30031 Seeking clear lacquer to be applied on silver plated copper wire [England]++++ At the moment, we are trying to develop a Silver plated copper wire that remains bright and shiny all the time and therefore started to do some tests with different lacquers. The two problems encountered so far are: 1) The lacquered wire after a few months exposed to sunlight turn
into a yellow colour. Therefore, I would be glad if you could possibly look into this and let us know your thoughts. Just to give you some further information, the wire range goes from 0.25 mm. to 1.20 mm. The wire is electroplated (silver plating line) at 1.60 mm. and then drawn down to the above mentioned sizes. The production process is therefore continuous from reel to reel and the idea is to actually apply the lacquer continuously, as a final stage. Steve P.
Dear Reader: Sorry, but there is no provision for public reply to this particular letter because it appears to be a commercial inquiry rather than a technical question. Our supporting advertisers should reply privately.
Save
