finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 30030
Square Footage per Amp for hardcoat
How to figure Square Footage per Amps while running Hardcoat Anodize?
Terry Sanders
anodize - Cuba, Missouri, USA
It won't be less than 15 ASF or more than 35 ASF, but it's hard to give an exact number.
finishing.com
Brick, New Jersey
Thru a separate auxilliary 50 AMP ammeter, anodize a square panel (same alloy, same heat treatment) with 1/2 sq ft on each side. When you have 24 amps on that separate circuit panel, then you have 24 amps per square foot on every thing in the tank.
Editor's note:
   Mr. Probert is the
   author of
