HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 30017
Plating on magnesium
++++We are plating mag with nickel and we have the following questions.
1. Which nickel finish is the most durable?
2. What is the best thickness to produce a cosmetic and durable finish? The parts will be handled by doctors and the device is portable.
3. Are there cosmetic standards that we can call out on the drawing to insure quality parts. The parts will be manufactured in the US so any ASTM or US finishing type spec will work.
Don P [last name deleted for privacy by Editor]medical equip - Mt. View, California
The most durable nickel finish will be a duplex electroless nickel plating. After alkaline cleaning, acid etching/pickling, and fluoride activation, apply ~ 8 micrometers of low-phosphorus nickel, followed by ~ 17 micrometers of either mid-P Ni (6-9% P) or high-P Ni (> 10%). This duplex coating results in a more durable, corrosion resistant finish. The fluoride activation can be replaced with a zinc immersion followed by a copper strike. The standard ASTM B480 [link is to spec at TechStreet] provides details on preparation of Mg alloys by either electroless (autocatalytic) Ni or Zn immersion + Cu strike. I will let others discuss the cosmetic standards issue.
Best of luck with your project.
Toby PadfieldAutomotive module supplier - Michigan
