HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 30010
Selective copper etchant
I have the following question:
I have one microstructure which is composed of one layer of Ni(95%)/Fe(5%) (thickness: 350µm) and one layer of Cu (15µm). I would like to etch selectively the copper; the Ni/Fe should be not attacked. Do you know some etching solutions ding this ? What is the process ?
I'll read that the sample should be totally clean and that the parts should be wet (why)?
Thank you very much in advance.
Pascal MEYERElectroplating and etching - Karlsruhe, Baden-Wurtemberg, Germany
You can use next solution:
210 gm natrium sulphide
15 gm sulphur
20 C temp. (according to Praktische galvanotechnik,Saulgau 1997.)
- Zagreb, Croatia
You may want to look at US Patent 5,304,284 (Jagannathan et al). A working formulation based on this patent is isopropanol or ethanol based, with added 2-butene-1,4- diol, triethylorthoformate, and copper tetrafluoroborate (I don't recall the exact ratios). I used it successfully on structures containing copper and NiFe alloys. Of course any non-R&D use probably requires licensing.
Emanuel I. Cooper- Yorktown Heights, New York
