HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 29081
Phosphating of tool steel
++++We use a casting of CH13 (hot worked tool steel investment casting)for our component making. This casting undergoes heat treatment (spherodising, machining, gas carburising, hardening and tempering, Hardness = 60 HRC) followed by sand blasting for surface cleaning.
While performing manganize phosphating, we find white patches. We are looking for a unifirm black colour. Can some one help to avoid white patches. Phosphating is followed by tectyl 272 oiling. Corrosion test (as per ASTM ASTM B-117 [link is to spec at TechStreet]) on the component with white patches show a good corrosion resistance.
G R PatelManufacturer, Power Equipments - Vadodara, Gujarat, India
