HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 29078
RECOATING OF OPC DRUMS
HAI, I AM P.BHARATH FROM CHENNAI. I HAVE NEARLY 200 CUSTOMERS (HP PRINTERS). AND THEN I AM REFILLING FOR THEM. THOUGH I HAVE LOT OF OPC DRUMS WITH ME (USED). JUST I WANT TO KNOW IS THERE ANY POSSIBILITY TO RECOAT THE DRUM? P.BHARATH- CHENNAI, TAMILNADU, INDIA ++++ I just want to know whether it is possible to recycle opc drums, how to clean them etc., to protect environment Nandyala Rama Satyanarayana Reddypaper - Guntur, A.P. India +++++ Is there is any technique for re coating OPC printer drums? Gurjot Pal SinghComputer Teacher - Jalandhar, Punjab, INDIA +++++ Yes, Gurjot, there is. I am not experienced in this, but I understand that it starts with a small lathe on which you mount the drum because the coating must be applied to a rotating drum, not by dipping. There are about a dozen companies that sell the lathes, recoating chemicals, and miscellaneous cleaners, swabs, and peripherals.
