finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 29026
Prevent water corrosion with aluminum
We manufacture large (3x7ft), re-circulating water fountains sold by high-end retailers for use outdoors. We would like to use aluminum vs. stainless steel for the water basin and other components. The decoratively grained finish must be protected. Only 10 inches of the 1x3" tube are in constant water contact. The remainder is subject to typical weather conditions. 1)Are BOTH clear anodization and clear powder coating really necessary, as I have been told? 2)Would a small zinc plate in the water basin stop the corrosion? If the water ran through a galvanized pipe (which could be incorporated into the design easily), would enough zinc slough off to stop the corrosion? 3)Where do I go to get a definative answer? 4)Any other suggestion?
MK Burdick
water fountain manufacture - Seattle, WA, USA
You can use titanium - expensive but far better than Al or SS.
- Zagreb, Croatia
