Letter 29016
Plating aluminum in acid tin
We plate copper bus bar in tin and in silver. I wanted know how we
could plate aluminum bus bar in tin. What is the process to this.
Howard Leatherwood
Plating shop - Pearland, Texas, United States
You cannot electroplate directly onto aluminum because it is so
active that it forms a passive skin instantly. The normal procedure
is to immersion plate zinc onto the aluminum via a zincating bath,
and then proceed with copper and tin. As an alternative,
Atotech offers a proprietary
sequence for plating aluminum busbar called Alstan.
finishing.com
Brick, New Jersey
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
