Letter 29015
Density of chemical bath changes
I Electropolish Steel My Chemical Bath has a composition
phosphoric acid : sulphuric acid: water in the ratio 6:3:1 They are
all commercially pure acids The tank capacity for elctropolishing is
600 lt or 150 gallons Temperature 60-80 degrees C , 10volts, 400-420
Amps The Component being Electropolished is 3 sq inches I get a very
good shine but after a month the density drops and amperage falls to
9 volts for the full capacity of the rectifier and the shine becomes
very bad.
The reason that this happens is because when steel gets
electropolished iron is released in form of phosphates , sulphates
and some free irons and nickel, which take a very long time to
settle, and this is the reason the current does not flow.
Is there any additive that can be added to remove the iron so that
current can pass through and we do not have to throw away this bath
solution every 20 days. Or there should be some way how the sludge
can settle quicker. Any Help would be appreciated.
Rajiv Jain
Electropolishing - Aurangabad, Maharashtra, India
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
