finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 29014
Post Wash of Nitric solution from passivate
I am cuurently producing a stainless steel hinge (304 ss) that requires passivate. If the hinge is not taken apart, the (2) leaves and the hinge pin, does the Nitric acid from passivate have any adverse effect to the stainless if not completely washed?
TED HOFFMANN
JOB SHOP - MACHINING - Caledonia, MICHIGAN, USA
The nitric acid left on the spring will definitely cause problems. You can get pit corrosion upon ageing in addition to the hazard of the acid itself when it might touch another surface.
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
