HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 28078
Deburring using an electrolyte
I am chasing someone who sells a process that removes machining burrs and tool marks on a microscopic level and leaves a bright, polished surface on aluminum and stainless-steel components. The process involves the metal part is immersed as the anode in a bath of near neutral cold non- fuming electrolyte.
We manufacture four wheel drive accessories including side steps. The side steps have an aluminium checker plate (tread plate) top. After the checker plate is laser cut to size (face down) the face is left with a burred edge. The checker plate is 2.5 mm thick, and the largest side step dimension would be approximately 2.2 meters long by approximately 0.25 meters wide. Due to the time difference between the U.S and Australia please contact me on email.
Matthew Loughnansheet metal - Melbourne, Victoria, Australia
Readers: This site is made available for camaraderie & technical info exchange by our supporting advertisers, and they will contact the inquirer privately regarding their commercial needs. Please offer comments on any technical issues, but not sourcing suggestions or testimonials. Thanks!
