Letter 28067
Restoration of Architectural Aluminum
I'm concerned about the condition of some architectural aluminum
found in an urban train station. The station was constructed between
1932 and 1937 and all of the aluminum used for the semi-sheltered
waiting rooms (they are located within a train shed) is original. The
aluminum is slightly pitted and understandably dull and whitish (the
original finish was satin) in many places. An aluminum coating has
been suggested, but I seem to think that a mild, manual
buffing/polishing would be better. Any other suggestions?
Marianne Walsh
State Historic Preservation Office - Trenton, New Jersey, U.S.
Dear Marianne!
You must clean it with some very mild detergent/pH neutral are
best/. After that you must rinse it well/distilled water is best/ and
then polish it manual. And you may think about some good clearcoat.
- Zagreb, Croatia
Dear Reader, please --
- Answer or follow-up on this subject (in non-commercial
fashion).
- Post a new
question or inquiry on a different subject.
