Letter 28059
Need to remove rust on vinyl siding
Wanting to get rust stains off my chimney that the metal is
started to run rust down the side of the house in the front. I heard
that will will manatic acid is that true and will I need to get a
professional to do the work or will that work with just a hose
spraying it off... I have a light beige vinyl siding ... thank you.
Deborah Large
homeowner - Virginia Beach, Virginia
Should I read here,
Muriatic Acid [link is to product info at Amazon] (hydrochloric
acid) instead of manatic acid? This will work most likely, as might
citric acid. You would want to be careful your siding is not damaged,
and so might want to try a small spot first. Rust is basically iron
oxide, and that is attacked by a number of acids. The trick is to
find the simplest and safest one that is effective and that does not
attack the siding. I would try citric acid first, and then
hydrochloric, though the latter is likely much easier to work with!
Rubber protective gloves [link is to product info at Amazon], and
avoiding the fumes, etc., are in order.
Vincent E. Summers
- Charlottesville, Virginia
An easy and safe way to get rid of "rust" stains on vinyl siding
is to use "Lime-A-Way [link is to product info at Amazon]"
cleaner. I worked as a maintenanceman for a local mobile home sales
company and one of my responsibilities was to pressure wash the
houses and keep the rust stains off. All of the houses used vinyl
siding. For regular cleaning, use a diluted solution of chlorine
bleach and water (about 1 in 10 parts). Bleach is a surface tension
inhibitor (lubricant). Any built up dirt will run off of the vinyl
siding within 2 to 3 minutes, then just spray fresh water on the
siding. The rust stains are not real rust, but lime deposits. I spray
the deposits with Lime Away and the deposits will dissolve within 1
or 2 days.
Raymond Bliss
- Jacksonville, Florida
- Ed. note: You're experienced at it, Raymond, and if it
works, it works. But we have a hard time agreeing with you that
the deposits are lime.
I have been watering my yard and not even caring about the well
water hitting the siding on my garage and side of my house. I've read
that possibly Lime Away for a form of citric acid or hydrochloric
acid might work. How would I apply these solvents and is there
something in a name brand available that might be easier on me?
thanks a lot in advance!
Ted Trulley
- Mokena, Illinois
July 18, 2008
I have spent all week trying to get the rust off my vinyl
siding and finally found the magic. It's called
RustAid by WM Barr
and Co. Spray it on in a sprayer straight and the rust is
gone in minutes. Then just hose it down. It took a Gallon to
do 2 sides of the house. It comes in a maroon container.It
is in with the heavy household cleaners. There is also one
for indoors that is in a quart bottle.I tried Clorox
straight and CLR and Limeaway but it didn't budge the rust.
This RustAid is awesome.
MaryBeth Ruger
- Virginia Beach Virginia
July 27, 2009
I purchased an expensive vinyl siding rust remover and a bottle of
"CLR". Neither one worked....at all!
By chance I bought a bottle of "The Works" at the dollar general
store because it said it will remove rust from toilets. What did I
have to lose? Just $1.
I was pleasantly surprised. It removed the rust stains on vinyl
siding almost instantly. It is 1/5th the cost of "lime-a-way" and
"CLR" plus you can cut it to a 50/50 mixture with water and it still
works great.
Apply to concrete sidewalks and driveways at 100% concentration and
it will clean it to a like new finish.
John Schmitt
- Granger, IN USA
