finishing.com logo ips1
HOME FAQs BOOKS JOBS: Help Wanted Suggestions      you are here: Hotline/Forum => Letter 28031
Embrittlement after yellow passivation
We are using Zinc plating (yellow passivation) on CRS ( EDD grade) sheet used as drawn can cans. We noticed an embrittlement of the steel after plating. This embrittlement was so bad that when two such products were hit against each other they developed longitudinal cracks (cracks along the axis of the can). Could you pl suggest a cause and a possible remedy.
Arun Bhardwaj
automotive component manufacturing - Gurgaon, Hryana, India
Mr Bhardwaj
Please follow this procedure
Plate Zinc
Rinse x 2 times
Nitric acid 1 percent dip. 10 secs.
Dry.
De embrittle at 220 Centigrade for 120 minutes. Check and establish time.
Cool in air naturally.
Activate in 1 % Nitric. After component is cool.
Chromate as needed.
This is the procedure to eliminate Hydrogen Embrittlement after plating. Before Passivation. Good Luck.
Asif Nurie
Atlanta Global
New Delhi, India
