HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 27074
Solderability problem with tin plating
We know that tin plating gives excellent solderability but recently we have encountered difficult solderability at our tin plating (iron base substrate) electrical terminal. I would like to know what has caused the difficult solderability of the tin plating? I do not reckon is the formation of oxide layer as our SEM/EDX result does not detect the presence of oxygen.
Maung San ZawEngineer - Singapore
It would be handy to see the parts concerned, but if this is not possible, so be it. I am surprised there is no evidence of oxygen on the tin because tin easily forms an oxide. What other elements have been detected? I wonder if insufficient tin has been put down and when you have heated the tinned substrate as you solder, the tin has diffused into the iron base to form iron-tin alloys. This could easily cause problems with solder as the iron-tin alloy does not wet as easily as iron.
Trevor Crichton R&D practical scientist The Pheasantries - Chesham, U.K. |
