HOME FAQs BOOKS JOBS: Help Wanted Suggestions you are here: Hotline/Forum => Letter 27028
Detecting thin aluminum phosphate coating
For electrolytic capacitor, the aluminum foil always reacts with water to form oxide. So, some manufacturer will put the foil in phosphoric acid to form a protective layer (aluminum phosphate). So, how to detect this layer? what kind of method can be use?
I got a sample with a very thin (about 10um) coating of aluminum phosphate. Does anyone know how to detect this coating?
El NinaStudent - Hong Kong
Surface phosphorous on aluminum is detectable and measurable using EDAX - also, the aluminum phosphate is a dielectric and a measurement of impedance through the aluminum will correlate with the amount of aluminum phosphate on the surface- are commercial samples of the treated foil available?
David Hanke- San Marcos, California, USA
